-Boundary
Creates a polyline that forms a boundary inside a closed area.
command bar:  -Boundary
alias:  -bo
: -boundary
Advanced/<Internal point>: (Pick a point inside a closed area, or type A.)
Advanced/<Internal point>: (Pick a point inside another closed area, enter A, or press Enter to end the command.)
Internal point
Specifies a point inside the closed area; enter x,y coordinates or pick a point in the drawing.
Advanced
Boundary set
Specifies the entities to consider for creating boundaries:
Specify candidate set for boundary - enter E or N.
  • Everything - selects all entities in the current viewport.
  • New - prompts you to select entities.
Island detection
Toggles whether islands are hatched over or not:
Do you want island detection? - enter an option.
  • Yes - all islands are made into boundaries, as well as the outermost area.
  • No - islands are ignored; boundary is created of outermost area only.
  • Outer only - ignores innermost areas; boundary is created between outermost area and islands.
eXit
Returns to the original prompt.
Grips Editing
Boundaries can be edited directly through grips:
  1. Select the boundary. Notice that it has many grips.
  2. Drag a grip to stretch the boundary.
BHatch and Hatch - place boundaries and hatch patterns through a dialog box.
-BHatch and -Hatch - places boundaries and hatch patterns through the command bar.
Boundary places a polyline boundary inside closed areas through a dialog box.
Properties - changes the properties of boundaries.
Region - creates boundary-like regions.
Settings - specifies the default parameters for boundaries.
