DdSetVar
Displays the Settings dialog box (short for "dynamic dialog set variables").
command bar:  ddsetvar
transparent:  'About
alias:  settings
: ddsetvar
Displays the Settings dialog box:
Change settings, and then click X.
Categorized
Lists system variables in categories.
Alphabetical
Lists system variables in alphabetical order by setting name.
Export
Exports the settings to a .csv file (comma-separated values); displays the Export Settings dialog box.
Click Save. The file can be opened in a word processor, spreadsheet, or database program.
Drawing
Jumps to the Drawing section of the dialog box.
Dimensions
Jumps to the Dimensions section of the dialog box.
Program Options
Jumps to the Program Options section of the dialog box.
Find Options
Displays the Find Options dialog box:
Find What
Enter the text you wish to search for.
Find
Click to start the search.
Find Where
Specifies where to search for text:
  • In Variable Names - search the names of system variables, such as "Bindtype."
  • In Variable Titles - search the titles of variables, such as "Xref Bind Type".
  • In Variable Help - search the help text, such as "Controls the handling of xref names when binding xrefs or when xrefs are edited in-place."
Apply
Applies changes made to the Find Where options.
Match Case
Matches the pattern of upper and lowercase letters.
Find Field
Enters the name of a system variable, title, or help for Bricscad to search. The field changes color:
Green - another entry exists for the search phrase; click the Find Next button.
Blue - the last entry has been reached; click Find Next to start again at the beginning.
Orange - text does not exist in this dialog box.
Find Previous
Finds the previous entry
Find Next
Finds the next entry.
Related Command
SetVar - change the values of system variables through the command bar.
