Dist
Reports the distance and angle between two points.
command bar:  dist
transparent:  'dist
alias:  di
menu bar:  Tools | Inquiry | Distance
toolbar:  Inquiry |
: dist
Starting point for distance: (Pick a point, or enter coordinates.)
End point: (Pick another point, or enter coordinates.)
Sample response:
Distance = 4.3167,  Angle in XY Plane = 220,  Angle from XY Plane = 0
Delta X = -3.3302,  Delta Y = -2.7466,  Delta Z = 0.0000
Starting Point for Distance
Specifies the first point from which the measurement takes place.
End Point
Specifies the other point.
Area - reports the area, circumference, and perimeter of entities.
Id - reports the x,y,z coordinates of picked points.
List - lists the area and other parameters of entities in the command bar.
MassProp - reports the properties of solid models and regions.
Properties - lists the area and other parameters of entities in a palette.
