DimEdit
Works with Classic, Pro , Linux
Changes the wording and angle of dimension text; changes the angle of extension lines.
command bar:  dimedit
aliases:  ded, dimed
menu bar:  Dimension | Make Oblique
toolbar:  Dimensions |
: dimedit
Edit dimension:  Edit text/Oblique lines/Rotate text/<REstore text>: (Enter an option, or press Enter to restore the dimension.)
Left: Original dimension text; right: Dimension text edited with the Edit Text option.
Left: Original extension lines; right: Extension lines set to an angle with the Oblique Lines option.
Left: Dimension text at original angle; right: Dimension text rotated with the Rotate Text option.
Edit Text
Changes the text; prompts you:
New dimension text <> - specify the new text; the <> symbol indicate the default text so that you can insert text in front or behind the default, such as "Adjust to <> inches."
Selection dimensions to replace with new text - choose one or more dimensions; prompt repeats until you press Enter.
Oblique Lines
Rotates (obliques or slants) the extension lines; useful for creating isometric dimensions. Prompts you:
Select linear dimensions to make oblique - choose one or more linear dimensions; prompt repeats until you press Enter.
Enter obliquing angle - specify the angle. The angle is measured counter clockwise from the positive x-axis.
Rotate Text
Rotates dimension text; prompts you:
Angle of dimension text - specifies the angle. The angle is measured counter clockwise from the positive x-axis.
Select entities to rotate text - choose one or more dimensions; prompt repeats until you press Enter.
REstore Text
Restores the text to its original position; this option does not restore edited text or obliqued extension lines. Prompts you:
Select dimensions to restore text to default position - choose one or more dimensions; prompt repeats until you press Enter.
