Leader
Draw leaders.
command bar:  leader
aliases:  le, lead
: leader
Start of leader: (Pick a point.)
Next point: (Pick another point.)
To point: Format/Undo/<Annotation>: (Enter an option, or pick another point.)
First line of annotation text <options>: (Enter text, or type O.)
Next line of annotation text: (Press Enter to exit command.)
Leaders consist of the following parts:
Start of leader
Specifies the starting point of the leader line.
Pick a point or enter x,y coordinates.
To place the leader accurately, use entity snaps.
An arrowhead is placed at the starting point automatically.
Next point
Specifies the first vertex of the leader line.
To point
Specifies the next vertex, or the endpoint of the leader line.
Format
Specifies the leader style; prompts you:
Arrow/None/SPline/STraight/<Exit> - enter an option.
Arrow
Draws an arrowhead at the leader's start point (default).
None
Draws no arrowhead.
SPline
Draws the leader as a spline.
STraight
Draws the leader as straight line segments (default).
Exit
Returns to the previous prompt.
Undo
Undoes the last leader line segment.
Annotation
Starts adding text to the end of the leader line.
The leader can have one or more lines of text.
Caution: the annotation is independent of the leader line; when moving a leader, be sure to include the annotation in the selection set.
Specifies the first line of text.
For no text, press Enter instead of entering text.
Specifies the second line of text.
Options
Specifies the type of annotation.
Do not enter "O" to access this option; press Enter only; prompts you:
Dimension text options: Block/Copy/None/Tolerance/<Mtext> - enter an option.
Block
Uses a block as the annotation; displays prompts identical to that of the -Insert command:
? to list blocks in drawing/~ to open the file dialog/<Block to insert> - enter an option.
See -Insert command for details on these options.
Copy
Uses any other entity in the drawing as the annotation; prompts you:
Select an entity - choose an entity, other than the leader itself.
None
The annotation is kept blank.
Tolerance
Uses tolerance notation for the annotation; displays the Geometric Tolerance dialog box.
See Tolerance command.
Mtext
Uses mtext (multi-line text) for the annotation; displays the Multiline Text dialog box.
See MText command.
DimLeader - places leaders with text, blocks, entities, or tolerances.
