Move
Moves entities.
command bar:  move
alias:  m
menu bar:  Modify | Move
toolbar:  Modify |
: move
Select entities to move: (Choose one or more entities.)
Entities in set: 1
Select entities to move: (Choose more entities, or press Enter to continue.)
Enter base point: <Displacement> (Pick a point, enter x,y coordinates, or type D.)
Enter second point: <ENTER to use base point as displacement> (Pick another point, or press Enter.)
Specifies the entities to be moved.
Enter base point
Specifies the starting point.
Pick a point in the drawing, or enter x,y coordinates.
Use entity snap modes to ensure accuracy.
To move entities horizontally or vertically, hold down the Shift key.
Enter second point
Specifies the destination for the entities.
Displacement
Specifies the distance to move the entities; prompts you:
Enter displacement point - pick a point.
Enter x,y,z coordinates to specify the distance in the x, y, and z direction.
To move 10 units only in the x direction, enter 10,0.
When using the base point as displacement, Bricscad measures the distance from the origin (0,0,0) to the x,y,z coordinates of the base point.
Caution: this option can move entities farther than you may expect.
PEdit - moves the vertices of polylines.
CutClip - moves entities from the drawing to the Clipboard.
