Starts new drawings.
command bar: new
shortcut: Ctrl+N
menu bar: File | New
: new
Choose a DWT template file or DWG drawing file, and then click Open.
DWT template files define the properties of new drawings.
DWG drawing files are opened like the Open command.
When the StartUp system variable is turned on, this command displays the same dialog box as the NewWiz command
Specifies the file name. To open more than one file at a time, hold down the Ctrl key while selecting file names. |
Chooses the type of drawing file:
Toggles read-only status of drawings:
Use the SaveAs command to save by another name. Template drawings are always opened as read-only. |
Toggles previews of the drawing:
Many template files are empty, and appear to not have a preview. |
Opens the file. |
Units - sets units through the Settings dialog box.
-Units - sets units through the command bar.
NewWiz - sets units and other parameters for new drawings.
QNew - opens new drawings.
| Bricscad™ коммерциализирован Bricsys NV. Bricsys NV и Vondle NV являются полностью дочерними компаниями Menhirs NV. Авторские права © 2001- Menhirs NV - Все права защищены. |
