Sets units of linear and angular measurements in the command bar.
command bar: -units
transparent: '-units
alias: -un
status bar: x,y,z-coordinates
: -units
Unit mode (LUNITS):
1. Scientific 4.225E+01
2. Decimal 42.25
3. Engineering 3'-6.25"
4. Architectural 3'-6 1/4"
5. Fractional 42 1/4
Unit mode 1-5 <2>: (Enter a number.)
Number of decimal places for LUNITS 0-8 <4>: (Enter a number.)
Angular unit mode (AUNITS):
1. Decimal degrees 90.0
2. Degrees/minutes/seconds 90d0'0
3. Grads 100.00g
4. Radians 1.57r
5. Surveyor's units N 00d0'0"E
Angular unit mode 1-5 <1>: (Enter a number.)
Number of decimal places for angular units 0-8 <0>: (Enter a number.)
Angle 0 direction <0>: (Enter an angle.)
Do you want angles measured clockwise? <N>: (Type Y or N.)
Specifies the units of linear measurement. Enter a number between 1 and 5 corresponding to the list:
For metric units, choose 2 (decimal). (LUNITS refers to the system variable that stores the type of linear units.) |
Specifies the number of decimal places. Enter a number between 0 and 8:
This option affects the precision of fractions in architectural and fractional units:
Specifies the type of angular units. Enter a number between 1 and 5:
There are 400 grads in a circle. There are 2*pi radians (approximately 6.282) in a circle. The N and E in Surveyor's units refers to North and east. (AUNITS refers to the system variable that stores the type of angular units.) |
Specifies the number of decimal places. Enter a number between 0 and 8. |
Specifies the direction for 0 degrees. Enter an angle, or pick two points in the drawing. The default is the positive x axis. You can also rotate the drawing through the Snap command's Rotate option.
Specifies the direction in which to measure angles:
Right-click 72',42',0" (or other x,y,z coordinates) on the status bar for the shortcut menu:
Shortcut Menu |
Scientific Linear Units |
Chooses scientific as the working units. |
Decimal Linear Units |
Chooses decimal (metric) as the working units. |
Engineering Linear Units |
Chooses engineering as the working units. |
Architectural Linear Units |
Chooses architectural as the working units. |
Fractional Linear Units |
Chooses fractional as the working units. |
Relative |
Displays relative coordinates in the status bar. |
Absolute |
Displays absolute coordinates in the status bar. |
Off |
Displays coordinates only when points are picked. |
Properties |
Opens the Coordinates section of the Settings dialog box.
Coordinates
Specifies how coordinates are displayed in the status bar:
Units - sets units through the Settings dialog box.
NewWiz - sets units and other parameters for new drawings.
New - starts new drawing in Imperial or metric units.
| Bricscad™ коммерциализирован Bricsys NV. Bricsys NV и Vondle NV являются полностью дочерними компаниями Menhirs NV. Авторские права © 2001- Menhirs NV - Все права защищены. |
