Platinum
Platinum
Platinum
Closes gaps between two arbitrarily oriented flanges.
command bar: smflangeconnect
menu bar: Sheet Metal | Connect Flanges
toolbar: Sheet Metal | ![]()
: smflangeconnect
Select planar thickness faces of two flanges: (Select the face on the first flange.)
Entities/subentities in set: 1
The flanges are connected.
If SELECTIONPREVIEW is 2 or 3, thickness faces of flanges highlight. Press the TAB key to select obscured faces.
Quad cursor menu
Select the planar thickness faces of two flanges, then choose
Connect Flanges (
) in the Sheet Metal
command group.
No command options.
Procedures
SmFlangeBase - creates a base (initial) flange of a sheet metal part from a closed planar profile.
SmFlangeEdge - creates one or more flanges to a sheet metal part by pulling one or more edges of an existing flange.
SmFlangeRotate - rotates a selected flange of a sheet metal part with automatic selection of the rotation axis depending on the design intent.
SmUnfold - creates an unfolded 2D or 3Drepresentation of a sheet metal part.
