Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Changes the elevation and thickness.
command bar: elev
menu bar: Settings | Elevation
toolbar: Settings |
: elev
New current elevation <0.0000>: (Enter a new value, or press Enter to keep the current value.)
New current thickness <0.0000>: (Enter a new value, or press Enter to keep the current value.)
Specifies the elevation; enter a negative value for a negative elevation. The elevation is reported on the status bar as the z coordinate. The elevation is the height of the xy plane in the z direction. |
Specifies the thickness; the thickness begins at the elevation; enter negative values for thicknesses that are drawn downwards (negative z direction). The thickness is the extrusion distance (in the z direction) of non-3D entities, such as points and circles. When thickness is not 0:
Properties - changes the elevation (z coordinate) and elevation through a palette.
Change - changes the elevation and thickness of entities through the command bar.
Settings - sets the default elevation and thickness through the 3D section of the Settings dialog box.
