Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Toggles the display of the grid; sets the grid properties.
command bar: grid
transparent: 'grid
shortcut: F7
alias: g
menu bar: Settings | Reference Grid
toolbar: Settings |
status bar: GRID
: grid
Grid is off: ON/Snap/Aspect/<Grid spacing (x and y = 0.5000)>: (Enter an option.)
The extents of the grid are controlled by the Limits command.
Turns on the display of the grid. When the grid is on, this option changes to OFF. |
Sets the grid spacing to that of the snap spacing; see Snap command. |
Changes the aspect ratio of the grid; prompts you: Horizontal Spacing - specify the x distance between grid dots. Vertical Spacing - specify the y distance between grid dots. To change the grid to isometric mode, use the Snap command. |
Makes the x and y grid spacing the same; enter a positive number. |
Right-click GRID on the status bar for the shortcut menu:
Shortcut Menu |
On |
Turns on grid display. |
Off |
Turns off grid display. |
Settings |
Opens the Snap/Grid section of the Settings dialog box.
Grid mode |
Toggles grid display:
Grid unit |
Specifies the distance between grid dots:
There is no grid in the z direction. |
Snap - sets the snap spacing.
Limits - limits the extent of the grid dots.
Settings - sets grid parameters through a dialog box.
