Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Controls the display of the UCS icon (short for "user-defined coordinate system icon").
command bar: ucsicon
: ucsicon
ON/OFF/All/ORigin/Corner/<ON>: (Enter an option.)
You can also change the properties of the UCS icon in the User Coordinate System section of the Settings dialog box.
Turns on the display of the UCS icon.
Turns off the UCS icon. The UCS icon is not needed for 2D drafting. |
Applies changes to all viewports; repeats prompts: ON/OFF/All/ORigin/Corner - enter an option to apply to all viewports. This command normally applies only to the current viewport; use this option to apply changes to all viewports. |
Displays the UCS icon at the origin (0,0).
When the origin is outside of the viewport, the UCS icon is displayed at the lower-right corner of the viewport.
Displays the UCS icon in the lower right corner of viewports. |
Ucs - creates and modifies user-defined coordinate systems.
ExpUcs - creates, modifies, and deletes named UCSs through the Drawing Explorer.
SetUcs - sets the UCS to a specified viewpoint.
Plan - changes the viewpoint to the plan view of the WCS or current UCS.
DdVPoint - changes the 3D viewpoint of the drawing through a dialog box.
VPoint - changes the 3D viewpoint of the drawing through the command bar.
Settings - sets parameters of UCSs.
