Sets or returns the thickness of an object. The thickness specifies the distance a 2D object is extruded above or below its elevation
Syntax
Where:
DoubleVariable is a double-precision variable representing the thickness;
Object is an Arc, Circle, Line, Point, Polyline, Solid, Text, or Trace object.
Examples...
