Class AcadText
Member of BricscadDb
The Text object represents single-line text. To create text, use the AddText method. To modify or obtain information about text, use the following methods and properties:
| Methods | Properties | Events |
| ArrayPolar | Alignment | Modified |
| ArrayRectangular | Application | |
| Copy | Backward | |
| Delete | Document | |
| GetBoundingBox | Handle | |
| GetExtensionDictionary | HasExtensionDictionary | |
| GetXData | Height | |
| Highlight | Hyperlinks | |
| IntersectWith | InsertionPoint | |
| Mirror | Layer | |
| Mirror3D | Linetype | |
| Move | LinetypeScale | |
| Rotate | Lineweight | |
| Rotate3D | Material | |
| ScaleEntity | Normal | |
| SetXData | ObjectID | |
| TransformBy | ObjectName | |
| Update | ObliqueAngle | |
| OwnerID | ||
| PlotStyleName | ||
| Rotation | ||
| ScaleFactor | ||
| StyleName | ||
| TextAlignmentPoint | ||
| TextGenerationFlag | ||
| TextString | ||
| Thickness | ||
| TrueColor | ||
| UpsideDown | ||
| Visible |
