Class AcadArc
Member of BricscadDb
The Arc object represents a segment of a circle or ellipse. To create an arc, use either the AddArc method. To access the Arc object, use the following methods and properties.
| Methods | Properties |
| ArrayPolar | Application |
| ArrayRectangular | ArcLength |
| Copy | Area |
| Delete | Center |
| GetBoundingBox | Document |
| GetExtensionDictionary | EndAngle |
| GetXData | EndPoint |
| Highlight | Handle |
| IntersectWith | HasExtensionDictionary |
| Mirror | Hyperlinks |
| Mirror3D | Linetype |
| Move | LinetypeScale |
| Offset | Lineweight |
| Rotate | Material * |
| Rotate3D | Normal |
| ScaleEntity | ObjectID |
| SetXData | ObjectName |
| TransformBy | OwnerID |
| Update | PlotStyleName |
| Radius | |
| StartAngle | |
| StartPoint | |
| Thickness | |
| TotalAngle | |
| TrueColor | |
| Visible |
