Dimensioning tools overview
All tools to create dimension entities can be found either on the Dimensions toolbar or in the Dimensions menu.
Toolbar
Circles flyout
Menu
Icon
Tool name
Command
Linear
DIMLINEAR
Creates horizontal or vertical linear dimensions.
Aligned
DIMALIGNED
Creates linear dimensions which are aligned with the dimension points.
Rotated
DIMLINEAR
Creates rotated linear dimensions.
Angular
DIMANGULAR
Creates angular dimensions
Arc
DIMARC
Creates arc length dimensions
Leader
DIMLEADER
Creates a leader with or without text.
Center Lines
DIMCENTER
Draws center lines in circles and circular arcs.
Diameter
DIMDIAMETER
Creates diametrical dimensions in circles and circular arcs.
Radius
DIMRADIUS
Creates radial dimensions in circles and circular arcs.
Baseline
DIMBASELINE
Creates stacked linear dimensions.
Continue
DIMCONTINUE
Creates a chain of linear dimensions, starting from an existing linear dimension entity.
Ordinate
DIMORDINATE
Creates ordinate dimensions.
Tolerance
TOLERANCE
Defines the layout of geometric tolerances.
Make Oblique
DIMEDIT + O
Makes the extension lines of the selected dimension(s) oblique.
Edit Dimension Text
DIMEDIT+ E
Defines the dimension text of the selected dimension(s).
Rotate Dimension Text
DIMEDIT+ R
Rotates the dimension text of the selected dimension(s).
Reposition Dimension Text
DIMTEDIT
Lets you reposition the dimension text.
Restore Text Position
DIMEDIT
Undoes the rotation or repositioning of the dimension text of the selected dimension(s).
Apply Style
-DIMSTYLE + A
Applies the current dimension style to the selected dimension(s).
Save Style
-DIMSTYLE + S
Saves the current dimension settings in a new dimension style.
Restore Style
-DIMSTYLE
Sets the current dimension style.
Dimension Variable Status
-DIMSTYLE + ST
Displays the status of the dimension variables in the command bar and the Prompt History window..
