Works with Bricscad (Windows) Classic and Pro, Bricscad (Linux) Classic
Places linear dimensions horizontally, vertically, or rotated.
command bar: dimleader
aliases: dimlin, dli, dimhorizontal, dimrotated, dimvertical
menu bar: Dimension | Linear
Dimension | Rotated
toolbar: Dimensions |
: dimlinear
ENTER to select entity/<Origin of first extension line>: (Press Enter to dimension an entity.)
Select entity to dimension: (Choose a line, polyline, arc, or circle.)
Angle/Text/Horizontal/Vertical/Rotated: (Position the dimension line, or enter an option.)
Dimension text = \A1;4.0263
ENTER to select entity/<Origin of first extension line>: (Choose a starting point.)
Origin of second extension line: (Choose an ending point.)
Dimension text = \A1;6.6588
Press Enter to dimension a single entity. |
Specifies the line, polyline, arc, or circle to dimension; other entities cannot be dimensioned with this option. |
Locates the dimension line away from the entity; determines the length of the extension lines. |
Specifies the angle of the text; useful for keeping text horizontal with inclined dimension lines. Prompts you: Angle of dimension text - specify the rotation angle of the text. |
Specifies the text; useful for overriding the default measurement generated by Bricscad. Prompts you: Dimension text - specifies the replacement text. |
Forces the dimension to be horizontal; prompts you 'Angle/Text/<Location of dimension line>:'. |
Forces the dimension to be vertical; prompts you 'Angle/Text/<Location of dimension line>:'. |
Rotates the dimension by a specified angle; prompts you: Angle of dimension line - specify the angle of the dimension line. |
Specifies the origin of the first extension line. |
Specifies the origin of the second extension line. |
Grips Editing
Linear dimensions can be edited directly through grips:
Select the linear dimension. Notice the grips.
Drag either grip on the dimension line to move the dimension line; the extension lines change length.
Drag the grip on the text to relocate it; the dimension line moves along, and a leader line is added, if required.
Drag either grip on the extension lines to move the extension line; the dimension line changes length.
