Commands: INSERT, -INSERT, INSERTALIGNED and MINSERT
The Insert command lets you insert blocks through a dialog box.
The -Insert command inserts blocks by prompting in the command bar. Bricscad will lookup the block name in the block definitions in the current drawing. If the block is not found in the current drawing, the paths defined by the SRCHPATH system variable are searched. If the block is not found there either, Bricscad responds 'Could not find file <blockname>'
The Insertaligned command inserts a block entity, with easy alignment on existing entities. The Insertaligned command is similar to the Insert command, but during the placement the block will be dynamically aligned with existing lines, polylines, arcs or circles. The block is aligned with the entity to which the cursor snaps. If no entity is snapped, the block is aligned with the X-axis of the WCS.
The Minsert command Inserts a block as a rectangular array; combines the -Insert and Array commands (short for "multiple insertion").
You can choose to select an existing block definition or to insert an entire drawing as a block. When you insert a drawing, a new block definition is created in the current drawing. If you change the original drawing file, those changes have no effect on the current drawing unless you redefine the block by reinserting the changed drawing. When a block is inserted in a drawing, it is treated as a single entity.
General procedure to insert a block:
Specify a block definition or drawing file.
Specify the insertion point.
Specify the scale.
Specify the rotation angle.
NOTES |
INSUNIT in target drawing |
INSUNIT |
Centimeters |
Inches |
not specified |
Millimeters |
Inches |
not specified |
The Unit field under Block Unit is set by the INSUNITS (Insertion Units) settings variable in the source drawing. The Factor field expresses the relation between the value of the INSUNIT variable in the source drawing and the target drawing. E.g. if INSUNIT is Millimeters in the source drawing and Centimeters in the target drawing, the value of the Factor field is 0.1. The Scale factor of the block is 1,1,1. If INSUNIT in the source drawing is Unspecified (unitless), INSUNITDEFSOURCE is used. The value of the Factor field is 1.0 and the Scale factor of the block is expresses the relation between INSUNITDEFSOURCE and INSUNIT in the target drawing. If INSUNIT in the target drawing is Unspecified (unitless), INSUNITDEFTARGET is used. The value of the Factor field is 1.0 and the Scale factor of the block is expresses the relation between INSUNIT in the source drawing and INSUNITDEFTARGET. If INSUNIT is unspecified (unitless) in both the source and the target drawing, INSUNITDEFSOURCE and INSUNITDEFTARGET are used. The value of the Factor field is 1.0 and the Scale factor of the block is expresses the relation between INSUNITDEFSOURCE and INSUNITDEFTARGET. The values of INSUNITDEFSOURCE and INSUNITDEFTARGET are saved in the registry and therefore apply to all drawings in which is INSUNIT is unspecified (unitless). |
Do one of the following
Click the Insert
Block... tool button (
) on the Draw 2D toolbar.
Choose Insert Block... in the Draw menu.
Type insert in the command bar, then press Enter.
The Inserts dialog opens.
In the Inserts dialog, do one of the following:
Select an existing block definition in the Name list.
Click the Browse button and select a drawing file.
(option) Check the Explode option to explode the block after insertion.
(option) Uncheck the Specify On-Screen option, then specify the Insertion Point by keying in the coordinates in the X, Y and Z fields.
On-Screen option, then specify the Scale by keying in the scaling factors in the
X, Y
and Z fields.
Check the Uniform Scale option to
equal the X, Y and Z scale
factors.
(option) Check the Specify On-Screen option to specify the Rotation angle when inserting the block.
Click the OK
button.
The command bar reads: Insertion point for block.
A prompt menu displays.
The command bar reads: Corner/XYZ/X scale factor
<1.000000>:
Right click or press Enter to accept the default
X scale factor.
The command bar reads: Y scale factor: <Equal to X scale
(1.000000)>:
Right click or press Enter to set the Y scale factor equal to the X scale factor.
The block is inserted.
To insert a block using the Blocks Explorer
Open the Drawing Explorer - Blocks dialog.
(optional) Choose either Detail View (
) or Icon
View (
Do one of the following:
Select a block, then do one of the following:
Click the Insert
Block button (
) on the Details toolbar.
Right click and select Insert from the context menu
When in Icon View, double click the block.
To select an external drawing, do one of the following:
Click the Insert
External tool button (
Choose Insert External in the Edit menu.
Right click, then choose Insert External in the context menu.
The Drawing Explorer - Blocks window closes.
The command bar reads: Multiple blocks/<Insertion point for block>:
<1.000000>:
X scale factor.
(1.000000)>:
The command bar reads: Rotation angle for block <0>:
Specify the rotation angle or right click to accept
the default rotation angle.
reopens.
(option) Repeat steps 3 through 8 to insert more blocks.
Close the Drawing Explorer - Blocks window.
To insert a block aligned with an entity
Make sure the appropriate Entity Snaps are active.
Type insertaligned or
insal in the command bar, then press
Enter.
The command bar reads: ? to list blocks in drawing/~ to open the
file dialog/<Block to insert> <name>:
Press Enter or right click to insert the most recently placed block again.
Type the name of an existing block definition in the command bar, then press Enter.
Type the name of an external block file in the command bar, then press Enter.
Type ~ (tilde) then press Enter to open the file dialog.
Snap to an entity.
The block is aligned with the entity.
Click to define the insertion point.
When you move the crosshairs, the block is mirrored about the
selected entity or a about a line tangent to the selected
entity.
Click to specify the mirroring of the block.
NOTE |
If you type the name of block in step 3, Bricscad will lookup the block in the block definitions in the current drawing. If the block is not found in the current drawing, the paths defined by the SRCHPATH system variable are searched. If the block is not found there either, Bricscad responds 'Could not find file <blockname>' |
NOTE |
The block is aligned as follows: The block is rotated so that its local Z-axis is parallel with the Z-axis of the active UCS, and its local X-axis should be parallel with the tangent to the entity at the position of the snap point. When you click a point on an entity the block is aligned with the entity. Then, by moving the mouse pointer around the insertion point, you can choose how the block should be mirrored. The origin point of the block lies on the entity. |
To insert multiple instances of a block in a rectangular array
Type minsert in the
? to list blocks in drawing/~ to open the file dialog/<Block to
insert>:
Type ~
(press and hold the Alt gr key,
then press the ~ key), then press
Enter.
The Insert Block file dialog
displays.
Select the drawing file you want to insert and press the
Open button (or double click the file
name).
Press Enter to accept the <Block to insert>.
Type a block name, then press Enter.
Optionally, type ? to display search for existing block
definitions.
The block is attached to the cursor.
block>:
The command bar reads: Corner/XYZ/X scale factor <1.00>:
To define the X scale factor, do one of the following:
Press Enter to accept the default .
Type the X scale factor, then press Enter.
Click to define the X scale factor graphically.
The command bar reads: Y scale factor: <Equal to X scale (current X scale)>:
Repeat step 5 to define the Y scale factor.
Press Enter to set the rotation angle to 0°.
Type a rotation angle, then press Enter.
Click to define the rotation angle graphically.
The command bar reads: Number of rows in the array <1>:
Type the number of rows, then press Enter or press
Enter for one row.
The command bar reads: Number of columns <1>:
Type the number of columns, then press Enter or
press Enter for one column.
The command bar reads: Vertical distance between rows, or spacing
rectangle:
Type the row spacing distance, then press
Enter.
The command bar reads: Horizontal distance between columns:
Type the column spacing distance, then press
Enter.
The block array is created as a single entity.
NOTES |
