Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Opens the Drawing Explorer dialog box; controls layers, layer states, linetypes, text styles, UCS coordinate systems, named views, blocks, dimension styles, externally-referenced drawings, and attached images.
command bar: explorer
menu bar: Tools | Drawing Explorer...
toolbar: Standard |
: explorer
Press F1 to access help.
Click X to close.
Shortcut |
New |
Ctrl+N |
Creates a new item. |
Delete |
Ctrl+D |
Erases the selected item. |
Purge |
Ctrl+P |
Purges the unused items. |
Cut |
Ctrl+X |
Copies the item to the Clipboard, and then purges it from the drawing. |
Copy |
Ctrl+C |
Copies the item to the Clipboard. |
Paste |
Ctrl+V |
Copies the item from the Clipboard. |
Rename |
F2 |
Renames the selected item. |
Select All |
Ctrl+A |
Selects all items. |
Sets the selected item as current. |
Toolbar |
Toggles the display of the toolbar. |
Status Bar |
Toggles the display of the status bar. |
Details |
Displays items in detailed format. |
Icons |
Displays items as items. |
Tree |
Displays items in tree form (applies to layer states, images, dimension styles, and external references only). |
Regen |
Updates the drawing display to reflect changes made in this dialog box. |
Toggle Regen |
Toggles automatic updating of the display. |
Show XRef Layers |
Toggles the display of layers found in attached externally-referenced drawings. |
Restore Explorer Default Layout |
Restores the layout of the Drawing Explorer to the default layout. |
Ctrl+N |
Creates new items. |
Ctrl+D |
Erases selected items. |
Ctrl+P |
Removes unused items from the drawing. |
Ctrl+X |
Ctrl+C |
Ctrl+P |
Pastes the item from the Clipboard. Copy and Paste are useful for copying items from one drawing to another. |
Displays items as icons. |
-Layer - controls layers through the command bar.
-Linetype - controls linetypes through the command bar.
-Style - controls text styles through the command bar.
Ucs - controls coordinate systems through the command bar.
-View - controls views through the command bar.
-Insert - inserts blocks through the command bar.
Insert - inserts blocks through a dialog box.
-Style - controls dimension styles through the command bar.
-XRef - controls external references through the command bar.
XAttach - attaches external references through a dialog box.
ImageAttach - attaches images through the command bar.
