Works with Bricscad (Windows) Classic, Pro and Platinum
Adjusts links of OLE entities embedded in or linked to drawings (short for "object linking and embedding").
command bar: olelinks
menu bar: Edit | Links
: olelinks
Change a setting for a link, and then click Update Now.
Use the InsertObj command to insert OLE objects in drawings.
Updates linked OLE entities. When the source file changes, use this button to update the copy in the Bricscad drawing. |
Opens the source file in the source application. This allows you to edit the source file. When done editing, choose Update & Exit from the File menu. |
Changes the source for the linked OLE entity. |
Breaks the link with the source file. When the link is broken, the OLE entity in the drawing no longer changes when the source file changes. |
Reports the path to the source file name. |
Reports the file type. |
Determines how the OLE entity in the drawing is updated, when the source changes:
OleOpen - creates package files of OLE entities
PasteSpec - pastes entities in several formats.
InsertObj - inserts foreign (non-Bricscad) objects into drawings
Insert - inserts DWG files in drawings.
ImageAttach - attaches raster images to drawings.
XAttach - attaches DWG files to drawings.
