Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Moves the entire drawing within the current viewport.
command bar: pan
transparent: 'pan
shortcut: PgUp, PgDn, Shift+Right, Shift+Left, Shift+Up, Shift+Down
aliases: p, -pan, -p
menu bar: View | Pan
toolbar: View | Zoom |
: -pan
Left/Right/Up/Down/PGLeft/PGRight/PGUp/PGDown/<Pan base point>: (Pick a point, or enter an option.)
Pan displacement point: (Pick another point.)
Specifies the pan distance's starting point. |
Specifies the ending point. |
Pans the drawing 5% to the right. The drawing is panned by 5% of the width of the current viewport. |
Pans the drawing 5% to the left. |
Pans the drawing 5% downwards. |
Pans the drawing 5% upwards. |
Pans the drawing 100% to the right. You can also press the Shift+Left cursor key. The drawing is panned by the entire width of the current viewport. |
Pans the drawing 100% to the left. You can also press the Shift+Right cursor key. |
Pans the drawing 100% upwards. You can also press the Shift+Up cursor key. |
Pans the drawing 100% downwards. You can also press the Shift+Down cursor key. |
-Pan - moves the drawing within the current viewport.
RtPan - pan the drawing in realtime.
Zoom - increases and decreases the size of the drawing within the current viewport.
RtZoom - performs real-time zooming of the drawing.
