Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Visually changes the size of the drawing within the current viewport.
command bar: zoom
transparent: 'zoom
alias: z
menu bar: View | Zoom
: zoom
Zoom: In/Out/All/Center/Dynamic/Extents/Left/Previous/Right/Window/<Scale (nX/nXP)>: (Enter an option, or pick two points for a windowed zoom, or enter a zoom factor.)
To zoom in and out at any time, roll the mouse's wheel back and forth.
Specifies the absolute zoom scale factor:
Specifies the zoom factor relative to the current zoom. For example, 2x makes the current view twice as large. |
Specifies the zoom factor in paper space relative to model space. For example, 2xp makes the model space view twice as large as the surrounding paper space. |
Zooms in by 50% (0.5) |
Zooms out by 50% (2.0). |
Displays the entire drawing; zooms to the larger of:
Zooms in or out about a specified center point; prompts you: Center of view - pick a point or enter x,y coordinates. Enter zoom factor (nX/nXP), or view height - enter a zoom factor or view height. The view height defines the zoom; it is the height of the current viewport.
Pans and zooms using a rectangular box which represents your view. When you choose the Dynamic option, a view extents or view limits is executed first. The original size of the view box matches the size of the previous view. A dashed rectangle indicates the area of the previous view. You can adjust the size of the view box dynamically, then move it to the part of the drawing you want to view. A x in the center of the view box indicates the positioning mode. A right pointing arrow indicates the resizing mode. Click to switch between the two modes.
Displays the drawing to the extents of entities; limits and frozen entities are ignored.
Zooms in or out with the lower left corner specified by a point; prompts you: Lower left corner - pick a point or enter x,y coordinates. Enter zoom factor (nX/nXP), or view height - enter a zoom factor or view height. The view height defines the zoom; it is the height of the current viewport.
Displays the previous view, whether set by the Zoom, Pan, or View commands. |
Zooms in or out with the upper right corner specified by a point; prompts you: Upper right corner - pick a point or enter x,y coordinates. Enter zoom factor (nX/nXP), or view height - enter a zoom factor or view height. The view height defines the zoom; it is the height of the current viewport.
Zooms in to a rectangular area; prompts you: First corner - pick a point or enter x,y coordinates. Opposite corner - pick another point or enter x,y coordinates.
RtZoom - performs real-time zooming of the drawing.
Pan and -Pan - move the drawing within the current viewport.
RtPan - performs real-time panning of the drawing.
View and -View - set up named views of drawings.
DdVPoint - changes the 3D viewpoint of the drawing through a dialog box.
VPoint - changes the 3D viewpoint of the drawing through the command bar.
RtRot - rotates the 3D viewpoint in realtime.
RtRotX - rotates the 3D viewpoint about the x axis in realtime.
RtRotY - rotates the 3D viewpoint about the y axis in realtime.
RtRotZ - rotates the 3D viewpoint about the z axis in realtime.
