Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Saves drawings in DWG drawing, DWT template, and DXF interchange formats; always displays a dialog box.
command bar: saveas
transparent: 'About
shortcut: Ctrl+S
aliases: save, sa
: saveas
Use the QSave command to save drawings without seeing this dialog box.
Selects the drive and folder in which to save the drawing. Click the droplist to access additional locations. |
Specifies the name by which to save the drawing:
Specifies the format of the saved file. Accept the default (AutoCAD 2007 .dwg) or click the droplist to choose another format. There are three basic formats:
Includes a preview image with the drawing file. The preview is a bitmap (raster) image of the drawing's view at the time it is saved. |
Saves the drawing. |
Cancels the command; does not save the drawing. |
Export - exports drawings in a variety of vector and raster formats.
QSave - saves the drawing without displaying the Save dialog box.
Save - saves the current drawing through a dialog box.
SaveAll - saves all open drawings.
SaveAsR12 - saves drawing in older formats.
SecurityOptions - sets a password to protect a drawing
