Works with Bricscad (Windows) Classic, Pro and Platinum, Bricscad (Linux) Classic and Pro
Creates wipeouts, blank areas in the drawing.
command bar: wipeout
menu bar: Draw | WipeOut
: wipeout
Frames/Polyline/<Start point>: (Pick a point, or enter an option.)
Next point: (Pick another point.)
Undo/<Next Point>: (Pick another point, or type U.)
Undo/Close/<Next Point>: (Enter another point, or type C to end the command.)
Use the DrawOrder command to move the wipeout in front or behind other entities.
Start point |
Specifies the staring point of the wipeout frame. Pick a point or enter x,y coordinates. |
Next point |
Specifies the next vertex of the wipeout frame. |
Undo |
Undoes the last segment. |
Close |
Closes the frame. |
Frames |
Toggles the display of the wipeout frame; prompts you: Enter display mode: OFF/<ON> - type OFF or ON.
Polyline |
Uses a closed polyline to construct the wipeout frame; prompts you: Select a closed polyline - pick a closed polyline. Only polylines composed of line segments are accepted. Delete selected polyline? Yes/<No> - determines whether the polyline is erased:
Grips Editing
Wipeouts can be edited directly through grips:
Select the wipeout. Notice that it has one grip at each vertex.
Drag a grip to stretch the vertex.
DrawOrder - changes the display order of overlapping entities.
PLine - draws polylines.
RevCloud - draws revision clouds.
