Class AcadDimStyle
Member of BricscadDb
The DimStyle object contains the settings that determine the appearance of a dimension. To access the DimeStyle object, use the following methods and properties:
Methods | Properties |
Delete | Application |
GetExtensionDictionary | Document |
GetXData | Handle |
SetXData | HasExtensionDictionary |
Name | |
ObjectID | |
ObjectName | |
OwnerID | |
© Menhirs NV. All rights reserved. |
