GetExtensionDictionary method
Returns the extension dictionary associated with an object
Syntax
RetObject = object.GetExtensionDictionary
Where:
     The object  this method applies to;it can be one of the following:
All Drawing Objects, AttributeReference, Block, Dictionary, DimStyle, Group, Layer, Linetype, PlotConfigurations, RegisteredApplication, TextStyle, UCS, View, Viewport, Xrecord.
     RetObject is Dictionary object
Examples...
GetExtensionDictionary method example
