HasExtensionDictionary property
Determines if the object has an extension dictionary associated with it.
Syntax
BooleanVariable = object.HasExtensionDictionary
Where:
     BooleanVariable is a variable (True or False) specifying whether the window has an extension dictionary or not.
     object  is the object or objects this property applies to;it can be one of the following:
All Drawing Objects, AttributeReference, Dictionary, DimStyle, Group, Layer, Linetype, RegisteredApplication, TextStyle, UCS, View, Viewport,  XRecord
Examples...
GetExtensionDictionary method example
