Class AcadTextStyle
Member of BricscadDb
The TextStyle object contains the settings that determine the appearance of text. To access the TextStyle object, use the following methods and properties.
Methods | Properties |
Delete | Application |
GetExtensionDictionary | BigFontFile |
GetFont | Document |
GetXData | FontFile |
SetFont | Handle |
SetXData | HasExtensionDictionary |
Height | |
LastHeight | |
Name | |
ObjectID | |
ObjectName | |
ObliqueAngle | |
OwnerID | |
TextGenerationFlag | |
Width |
© Menhirs NV. All rights reserved. |
