VerticalAlignment property
Sets or returns the Vertical alignment for  Attribute, AttributeReference or Text. It is set or returned using the VerticalAlignment constants shown below.
Syntax
integerVariable = object.VerticalAlignment
object.VerticalAlignment = <integer>
Where:
     integerVariable is a variable (or the constant itself) representing the vertical alignment value.
     object is the entity object for which you set or return the vertical alignment.
Horizontal Alignment Constant Index Value
acVerticalAlignmentBaseline
0
acVerticalAlignmentBottom
1
acVerticalAlignmentMiddle
2
acVerticalAlignmentTop
3
