Text object
Class AcadText
Member of BricscadDb
The Text object represents single-line text. To create text, use the AddText  method. To modify or obtain information about text, use the following methods and properties:
Methods Properties Events
ArrayPolar Alignment Modified
ArrayRectangular Application
Copy Backward
Delete Document
GetBoundingBox Handle
GetExtensionDictionary HasExtensionDictionary
GetXData Height
Highlight Hyperlinks
IntersectWith InsertionPoint
Mirror Layer
Mirror3D Linetype
Move LinetypeScale
Rotate Lineweight
Rotate3D Material
ScaleEntity Normal
SetXData ObjectID
TransformBy ObjectName
Update ObliqueAngle
  OwnerID
  PlotStyleName
  Rotation
  ScaleFactor
  StyleName
  TextAlignmentPoint
  TextGenerationFlag
  TextString
  Thickness
  TrueColor
  UpsideDown
  Visible
