Export to PDF
Command: EXPORT
Drawing files can be saved as a PDF file, optionally including layers.
Export to PDF settings
Choose PDF Export Options... in the File menu to display the PDF Export settings in the Settings dialog.
Exporting a drawing to PDF
  1. (option) Adjust the Export to PDF settings.
  2. Choose Export... in the File menu.
    The Export Drawing As dialog opens.
  3. In the Save as type: list select Adobe PDF (*.pdf).
  4. Select a folder to save the PDF file.
  5. (option) Type a name in the File name field to replace the default <DRAWING_NAME>.pdf name.
  6. Click the Save button to create the PDF.
