Command: XSPHERE
To create an X-Sphere
Do one of the following
Click the Sphere tool button () on the X-Solids toolbar.
Choose Sphere in the X-Solids menu.
Type xsphere in the command bar, then press Enter.
The Create X-Solid Sphere dialog displays:
(option) Select Radius or Diameter from the option button of the X-field.
To define the Parameters of the X-Solid sphere do one of the following:
Type the values in the Origin and X fields.
Select a value in the drop-down list.
Click a Pick button
() to define a parameter in the drawing.
Click the Pick All button to define all parameters in the drawing.
(option) Click the Manipulate... button to move or rotate the X-Solid sphere.
(option) Click the View... button to manipulate the view.
(option) Click the Preview button.
(option) Choose an After primitive creation operation to be executed after the X-Solid sphere is created.
Click the OK button to create the X-Solids sphere.
© Menhirs NV. All rights reserved. |
