Works with Bricscad (Windows) Pro and Platinum, Bricscad (Linux) Pro and Platinum
Performs Boolean intersection operations on 3D solids and 2D regions; removes all but common portions.
command bar: intersect
alias: in
menu bar: Model | 3D Solid Editing | Intersect
toolbar: 3D Solid Editing |
: intersect
Select ACIS object to intersect: (Choose one 3D solid and/or 2D region.)
Entities in set: 1
Select ACIS object to intersect: (Choose another 3D solid and/or 2D region.)
Entities in set: 2
Select ACIS object to intersect: (Choose more ACIS entities, or press Enter to perform the intersection.)
Bricscad removes all but common volumes and areas from the selected entities.
This command also applies to regions:
Caution: if solids and regions do not intersect, Bricscad erases them.
Specifies the 3D solids and/or 2D regions. Choose one or more entities; non-ACIS entities are ignored. |
Region - creates 2D regions from 2D entities.
XIntersect - Performs Boolean intersection operations on Acis solids and X-Solids; removes all but common portions.
XSlice - Cuts an ACIS solid or an X-solid with a plane; the result is a 3D solid cut in two. You can choose whether to keep both parts or just one.
XSubtract - Performs Boolean subtraction operations on Acis solids and X-Solids; removes one from the other.
XUnion - Performs Boolean union operations on Acis solids and X-Solids; adds one to another to form a single entity.
XCut - Trims or cuts ACIS solids and X-Solids using 2D profiles as cutting tools.
XPunch - Cuts ACIS solids and X-Solids using 2D profiles as cutting tools.
XTrim - Trims ACIS solids and X-Solids using 2D profiles as cutting tools.
