Works with Bricscad (Windows) Pro and Platinum, Bricscad (Linux) Pro and Platinum
Performs Boolean subtraction operations on 3D solids and 2D regions; removes one from the other.
command bar: subtract
alias: su
menu bar: Model | 3D Solid Editing | Subtract
toolbar: Solid Editing | ![]()
: subtract
Select ACIS object to subtract from: (Choose the first set of one or more 3D solids and/or 2D regions.)
Entities in set: 1
Select ACIS object to subtract from: (Choose more ACIS entities, or press Enter to continue.)
Select ACIS objects to subtract: (Choose the second set of one or more 3D solids and/or 2D regions.)
Entities in set: 1
Select ACIS objects to subtract: (Choose more ACIS entities, or press Enter to continue.)
The result depends on the order in which ACIS entities are selected.
Select the sphere, and then subtract the cylinder:
Select the cylinder, and then subtract the sphere:
This command also applies to regions:
Specifies the ACIS entities that will have a portion removed. Choose the first set of one or more 3D solids and/or 2D regions. |
Specifies the ACIS entities that will be removed. Choose the second set of one or more 3D solids and/or 2D regions. |
Union - performs Boolean union operations on 3D solids and 2D regions; adds one to another to form a single entity.
XIntersect - Performs Boolean intersection operations on Acis solids and X-Solids; removes all but common portions.
XSlice - Cuts an ACIS solid or an X-solid with a plane; the result is a 3D solid cut in two. You can choose whether to keep both parts or just one.
XSubtract - Performs Boolean subtraction operations on Acis solids and X-Solids; removes one from the other.
XUnion - Performs Boolean union operations on Acis solids and X-Solids; adds one to another to form a single entity.
XCut - Trims or cuts ACIS solids and X-Solids using 2D profiles as cutting tools.
XPunch - Cuts ACIS solids and X-Solids using 2D profiles as cutting tools.
XTrim - Trims ACIS solids and X-Solids using 2D profiles as cutting tools.
