Continues linear and angular dimensions from the endpoint of the previous dimension.
command bar: dimcontinue
aliases: dco, dimcont
menu bar: Dimension | Continue
toolbar: Dimensions |
: dimcontinue
Continue: ENTER to select starting dimension/<Origin or next extension line>: (Choose a point for the endpoint of the second extension line.)
Dimension text = \A1;1.1135
Continue: ENTER to select starting dimension/<Origin or next extension line>: (Choose another point, or press Enter to exit command.)
Continue dimensions applied to a linear dimension
Continue dimensions applies to an angular dimension
Chooses the linear or angular dimension from which to continue dimensioning. |
Locates the endpoint of the second extension line; the first extension line is co-located with the second extension of the previous dimension. The command repeats this prompt until you press Esc. |
Procedures
To create continued dimensions
Grips Editing
Continued dimensions can be edited directly through grips:
Select the continued dimension. Notice the grips.
Drag either grip on the dimension line to move the dimension line; the extension lines change length.
Drag the grip on the text to relocate it; the dimension line moves along, and a leader line is added, if required.
Drag either grip on the extension lines to move the extension line; the dimension line changes length.
