Draws leaders.
command bar: dimleader
aliases: lead, leader
menu bar: Dimension | Leader
toolbar: Dimensions |
: dimleader
Start of leader: (Choose the starting point of the leader.)
Next point: (Choose the location of the first vertex.)
To point: Format/Undo/<Annotation>: (Choose another vertex, enter an option, or press Enter to enter text.)
First line of annotation text/<options>: (Enter text, or press Enter for annotation options.)
Next line of annotation text: (Enter additional text, or press Enter to exit the command.)
Leader drawn with arrowhead, straight line segments, and text annotation.
Leader drawn without arrowhead but with a spline segment, and tolerance annotation.
Locates the leader's arrowhead, and starts the leader line. |
Locates the first end point of the leader, or vertex. |
Locates the next end point. |
Formats the leader line: |
Arrow |
Draws the arrowhead. |
None |
Does not draw the arrowhead. |
SPline |
Draws the leader line as a spline. |
STraight |
Draws the leader line as straight segments. |
Exit |
Exits the Format options. |
Undoes the last segment. |
Press Enter to start entering the leader's annotation. |
Specifies the type of annotation: |
Block |
Uses a block as the annotation; prompts you: ? to list blocks in drawing - lists the names of blocks in the current drawing. ~ to open the file dialog - allows use of any .dwg file as a block for the annotation. Block to insert - specifies the name of a block in the drawing. |
Copy |
Uses any other entity as the annotation; prompts you: Select an entity - chooses an entity. |
None |
Leaves out the annotation. |
Tolerance |
Uses tolerance specification as the annotation; displays the Geometric Tolerance dialog box. See Tolerance command. |
Mtext |
Uses MText as the annotation; displays the Multiline Text dialog box. See MText command. |
Procedures
To create a leader and an annotation
Grips Editing
Leaders can be edited directly through grips:
Select the leader. Notice the grips.
Drag a grip on a vertex of the leader line to stretch the line segments on either side of the vertex.
Drag the grip at the arrowhead to move the leader anywhere in the drawing. (The text is independent of the leader line.)
Leader - places leaders with text, blocks, entities, or tolerances.
QLeader - draws leaders. Lets you specify the properties of the leader through a dialog box and reuse them for a series of leaders.
