Inserts blocks repeatedly, and inserts mirrored blocks.
command bar: insertaligned
alias: insal
: insertaligned
? to list blocks in drawing/~ to open the file dialog/<Block to insert> <defaultname>: (Type ? or ", or enter the name of a block.)
Multiple blocks/<Insertion point for block>: (Type M to insert the block repeatedly, or pick a point to insert the block once.)
Enter block mirroring control point: (Pick a point to mirror the block.)
Lists the names of all blocks in the current drawing. Prompts you: Block(s) to list <* for all> - press Enter to list all blocks, or enter part of a name to view some blocks. If necessary, press F2 to view the full list. See TextScr command. |
Displays the Insert Block dialog box. Choose a .dwg file, and then click Open. |
Specifies the name of the block to be inserted. |
Repeats the following prompts until you press Enter or Esc. This allows you to insert the same block many times quickly. |
Specifies the insertion point of the block in the drawing. |
Mirrors the block in one of four quadrants. Move the cursor to locate the mirrored block; the block is mirrored about its insertion point.
Insert - inserts blocks into drawings.
-Insert - insert blocks and prompts for attribute values through the command bar.
AttDef - defines attributes through a dialog box.
-AttDef - defines attributes through the command bar.
AttRedef - redefines a block and updates associated attributes.
AttSync - synchronizes attribute definitions in all block references of a specified block definition.
BattMan - manages the attributes of a block definition.
Block and -Block - create blocks from attribute definitions and entities.
EAttEdit - edits attribute values and most properties.
Explode - reduces blocks to constituent entities and attributes to tags.
Properties - edits block and attribute values and properties.
RefEdit - edits blocks and attributes in-place.
