Draws 3 and 4-sided regular and irregular 2D polygons; does not draw 3D solids.
command bar: solid
aliases: plane, so
menu bar: Draw | Solid
toolbar: Draw | Polygons |
: solid
Rectangle/Square/Triangle/<First point of plane>: (Pick a point, or enter an option.)
Second point: (Pick another point.)
Third point of plane: (Pick another point.)
Fourth point: (Pick another point to draw a quadrangle, or press Enter to draw a triangle and exit the command.)
Third point of plane: (Pick another point to draw an adjoining triangle, or press Enter to exit the command.)
Specifies the first corner of the polygon. Pick a point or enter x,y coordinates. |
Specifies the second corner of the polygon. BricsCAD ghosts the shape and size of the polygon. |
Specifies the third corner of the polygon.
Specifies the fourth corner of the polygon.
To draw a triangle, press Enter at the prompt. |
Starts drawing an adjacent polygon. The third and fourth points of the first polygon become the first and second points of the second polygon.
To end the command, press Enter at the this prompt. |
Draws one or more connected rectangles. |
First point of plane |
Specifies one corner of the rectangle. Pick a point, or enter x,y coordinates. |
Other corner of rectangle |
Specifies the other corner of the rectangle. |
Rotation angle for plane |
Specifies the rotation angle of the rectangle. Pick a point or enter an angle. The "Other corner of rectangle" prompt repeats to draw additional rectangles.
Draws one or more connected squares. |
Specifies one corner of the square. Pick a point, or enter x,y coordinates. |
Second corner of square |
The "Second corner of square" prompt repeats allowing you to draw additional squares. |
Draws one or more connected scalene triangles. |
Specifies one corner of the triangle. Pick a point, or enter x,y coordinates. |
Second corner of triangle
Specifies the second corner of the triangle. Cursor movement determines the orientation of the triangle. Move cursor to the:
The "Second corner of triangle" prompt repeats to draw additional triangles.
Procedures
Grips Editing
2D solids can be edited directly through grips:
Select the solid. Notice that it has one grip at each vertex.
Drag a grip to stretch the solid.
Fill - toggles the display of solid areas.
Trace - draws wide lines.
BHatch and Hatch - place solid-filled hatch patterns through a dialog box.
-BHatch and -Hatch - place solid-filled hatch patterns through the command bar.
Boundary and -Boundary place a polyline boundary inside closed areas.
Properties - changes the properties of solid.
