Overview
BricsCAD provides various tools to control the display and view orientation of your drawing.
These tools can be found either in the View menu or the View toolbar or both.
View toolbar and flyouts
Icon
Tool name
Command
Redraw
REDRAW
Refreshes the screen display in the current viewport.
Redraw All
REDRAWALL
Refreshes the screen display in all open viewports.
Regenerate
REGEN
Recalculates the screen display in the current viewport.
Regenerate All
REGENALL
Recalculates the screen display in all open viewports.
Update Fields
UPDATEFIELD
Updates the selected fields.
Real Time Pan
RTPAN
Pans the view dynamically.
Pan
PAN
Pans the view.
Real Time Zoom
RTZOOM
Zooms in/out dynamically.
Zoom In
ZOOM + I(*)
Zooms in on the center of the window by a factor of 2.
Zoom Out
ZOOM + O(*)
Zooms out from the center of the window by a factor of 1/2.
Zoom Extents
ZOOM + E(*)
Displays all the entities  in the drawing (referred to as the drawing extents).
Zoom Window
ZOOM + W(*)
You are prompted to pick two corners of a box on the existing view in order to enlarge that area to fill the display.
Zoom Previous
ZOOM + P(*)
Restores the displayed view prior to the current one.
Zoom All
ZOOM + A(*)
Displays the whole drawing as far as its drawing limits or drawing extents (whichever is the greater of the two).
Zoom Left
ZOOM + L(*)
Pick the lower left corner of the next view, then specify the magnification factor or the view height.
Zoom Center
ZOOM + C(*)
Pick the center of the next view, then specify the magnification factor or the view height.
Zoom Right
ZOOM + R(*)
Pick the upper right corner of the next view, then specify the magnification factor or the view height.
Real-Time Constrained Sphere
RTROT
Rotates the view dynamically in 3D.
  • Moving the mouse horizontally (parallel to the screen x-axis) rotates the view about the world z-axis.
  • Moving the mouse vertically (parallel to the screen y-axis) rotates the screen x-axis.
Real-Time Sphere Center
RTROTCTR
Rotates the view dynamically in 3D about a user-defined center point. Behaves like RTROT.
Real-Time Free Sphere
RTROTF
  • Moving the mouse horizontally (parallel to the screen x-axis) rotates the view about the screen y-axis.
  • Moving the mouse vertically (parallel to the screen y-axis) rotates the view about the screen x-axis.
Real-Time X
RTROTX
Rotates the view dynamically about the screen x-axis.
Real-Time Y
RTROTY
Rotates the view dynamically about the screen y-axis.
Real-Time Z
RTROTZ
Rotates the view dynamically about the screen z-axis.
Set View Point
DDVPOINT
Opens the Preset Viewpoints dialog.
Plan View
PLAN
Restores the plan view with respect to the WCS, the current UCS or a saved UCS.
Define View
DVIEW
Defines parallel and visual perspective views.
Save/Restore view
VIEW
Saves and restores named views.
Viewports
VPORTS
Manages viewports in model space.
Paper Space Views
MVIEW
Creates viewports in paper space.
2D Context
2DCONTEXT
Switches the drawing to a 2D drafting context.
3D Context
3DCONTEXT
Switches the drawing to a 3D modeling context.
(*) <command> <option>: type zoom followed by Enter, then type the command option letter, followed by Enter.
