3dPoly
Draws 3D polylines (short for "three dimensional polylines").
command bar:  3dpoly
alias:  3p
menu bar: Draw | 3D Polyline
toolbar:  Draw | Polylines |
: 3dpoly
Start of polyline: (Pick a point, or enter x,y,z coordinates.)
Next point: (Pick another point, or enter x,y,z coordinates.)
Undo/Next point: (Pick a point, or type U.)
Close/Undo/<Next point>: (Pick a point, or enter an option.)
Close/Undo/<Next point>: (Press Enter to end the command.)
You can edit 3D polylines with the PEdit command.
Start of polyline
Specifies the starting point of the polyline.
Next point
Specifies the next vertex of the polyline.
Press Enter to exit the command.
Undo
Undraw the last segment.
Close
Closes the polyline and ends the command.
Grips Editing
3D polylines can be edited directly through grips:
  1. Select the 3D polyline. Notice that it has a grip at the end of each segment.
  2. Drag a grip to stretch the segment.
Helix - creates a 2D spiral or a 3D helix.
PLine - draws 2D polylines.
PEdit - edits polylines.
Donut - draws fat circles out of polylines.
Polygon - draws regular polygons out of polylines.
Rectang - draws rectangles out of polylines.
