AttExt
Copies data from attributes to a text file via a dialog box.
command bar:  attext
aliases:  ax, ddattext
menu bar:  Tools | Attributes | Extract Attributes
toolbar:  Attributes |
: attext
Enter options, and then click Extract.
If you select blocks without attributes and non-block entities, BricsCAD ignores them.
The template file determines which attributes are extracted and the format of related data. For example, a template.txt file contains the following fields:
BL:NAME C008000
BL:NUMBER N003000
PRODUCT C016000
BL:X N016004
BL:Y N016004
This means that the AttExt command will extract the following values:
The table below lists all available data extraction parameters. The table uses the follow codes:
C = indicates alphanumeric field
N = indicates numeric field
fff = indicates width of field, in characters (max = 999)
ddd = indicates number of decimal places (max = 999)
0 = indicates zero.
Data
Format
Attribute tag (numeric)
Nfffddd
Attribute tag (alphanumeric)
Cfff000
Block name
BL:NAME Cfff000
Block counter
BL:NUMBER Nfff000
Block handle (identifier)
BL:HANDLE Cfff000
Block's layer name
BL:LAYER Cfff000
Block nesting level
BL:LEVEL Nfff000
Block insertion, x coordinate
BL:X Nfffddd
Block insertion, y coordinate
BL:Y Nfffddd
Block insertion, z coordinate
BL:Z Nfffddd
Block's rotation angle
BL:ORIENT Nfffddd
Block's x scale factor
BL:XSCALE Nfffddd
Block's y scale factor
BL:YSCALE Nfffddd
Block's z scale factor
BL:ZSCALE Nfffddd
Block's x extrusion direction
BL:XEXTRUDE Nfffddd
Block's y extrusion direction
BL:YEXTRUDE Nfffddd
Block's z extrusion direction
BL:ZEXTRUDE Nfffddd
Select
Dismisses the dialog box temporarily so that you can select blocks with attributes:
Select entities - choose one or more blocks with attributes.
Select entities - press Enter to return to the dialog box.
Extract in Drawing Exchange Format (DXF)
Exports the attribute values in DXF format as .dxx files.
This format is meant for use with other computer programs that can read .dxf files.
Extract in Comma Delimited Format (CDF)
Exports the attributes with commas separating values.
This format is meant for use with spreadsheets and databases.
Extract in Space Delimited Format (SDF)
Exports the attributes in fixed-width format.
This format is meant for use in word processors.
Template File
Specifies the name of the .txt template file.
The file must exist before this command is used.
Browse
Displays the Attribute Extract Template File dialog box. Choose a file, and then click Open.
Output File
Specifies the name of the output file,
Browse
Displays the Attribute Extract Template File dialog box. Specify a file name, and then click Save.
Extract
Exports the attribute values to the output file.
Procedures
Extracting attribute information
AttDef - defines attributes through a dialog box.
-AttDef - defines attributes through the command bar.
AttDisp - toggles the display of attribute text.
AttEdit - edits attribute values and properties.
-AttExt - extracts attributes from drawings to data files through the command bar.
AttRedef - redefines a block and updates associated attributes.
AttSync - synchronizes attribute definitions in all block references of a specified block definition.
BattMan - manages the attributes of a block definition.
Block and -Block - create blocks from attribute definitions and entities.
EAttEdit - edits attribute values and most properties.
Expode - reduces attributes to tags.
Insert - inserts blocks and prompts for attribute values through a dialog box.
-Insert - insert blocks and prompts for attribute values through the command bar.
Properties - edits attribute values and properties.
RefEdit - edits blocks and attributes in-place.
