Elev
Changes the elevation and thickness.
command bar:  elev
: elev
New current elevation <0.0000>:  (Enter a new value, or press Enter to keep the current value.)
New current thickness <0.0000>:  (Enter a new value, or press Enter to keep the current value.)
menu bar:  Settings | Elevation
toolbar:  Settings |
Specifies the elevation; enter a negative value for a negative elevation.
The elevation is reported on the status bar as the z coordinate.
The elevation is the height of the xy plane in the z direction.
menu bar:  Settings | Thickness
toolbar:  Settings |
Specifies the thickness; the thickness begins at the elevation; enter negative values for thicknesses that are drawn downwards (negative z direction).
The thickness is the extrusion distance (in the z direction) of non-3D entities, such as points, lines, polylines, arcs and circles.
When thickness is not 0:
  • Points become lines.
  • Lines and open polylines become planes
  • Arcs become curved surfaces.
  • Circles become cylinders.
  • Closed polylines become tubes.
Flatten - flattens 2D objects with thickness and allows to convert splines to polylines.
Change - changes the elevation and thickness of entities through the command bar.
Properties - changes the elevation (z coordinate) and elevation through a palette.
Settings - sets the default elevation and thickness through the 3D section of the Settings dialog box.
