Hyperlink
Links entities with files and Web pages with a dialog box.
command bar:  hyperlink
shortcut:  Ctrl+K
: hyperlink
Select entities: (Choose one or more entities.)
Entities in set: 1
Select entities: (Choose one or more entities, or press Enter to continue command.)
Change hyperlink options, and then click OK.
Each entity can contain just one hyperlink.
Link to file or URL
Specifies the hyperlink; can be the path and name of a file, networked file, or location on the Internet.
Locations on the Internet can include Web pages (http://), FTP sites (ftp://), and so on.
Examples of hyperlink syntax are as follows:
File - C:\foldername\filename.ext
Networked file - \\networkname\c\foldername\filename.ext
URL - http://www.bricsys.com or www.bricsys.com
Displays the Select File dialog box; choose a file, and then click Open.
Any type of file can be linked to.
Use relative path
Uses the path specified by Hyperlink Base.
Hyperlink base + relative path = full path or URL.
Remove link
Removes the link from the entity.
Hyperlink base
Specifies the path to relative hyperlinks.
Named location in file
Specifies a bookmark name.
The # character is used to specify locations (bookmarks) within files or Web pages, such as www.bricscad.sys#bookmark.
Hyperlink description
Describes the URL or file; this description is displayed in a tooltip when the cursor is paused over the entity; see HyperlinkOptions command.
-Hyperlink - attaches hyperlinks through the command bar.
HyperlinkOptions - sets options for hyperlinks.
Settings - sets options for hyperlinks in the Files section of the Settings dialog box.
Browser and Url - open the default Web browser.
OnWeb - opens the Bricsys home page in your computer's default Web browser.
Mail - attaches the current drawing to a message in the default email client.
