HyperlinkOptions
Toggles the display of the hyperlink cursor, shortcut menu, and tooltips.
command bar:  hyperlinkoptions
transparent:  'hyperlinkoptions
: hyperlinkoptions
Display hyperlink cursor and shortcut menu? [Yes/No] <Yes>: (Type Y or N.)
Display hyperlink tooltips?  [Yes/No] <Yes>: (Type Y or N.)
Toggles the display of the "hyperlink" icon and the Hyperlink submenu on shortcut menus:
  • Yes - turns on the display.
  • No - turns off the display.
When the cursor passes over entities with hyperlinks, the "world" icon is displayed.
When you right-click a selected entity that contains hyperlinks, the Hyperlink item is added to the menu.
Toggles the display of the hyperlink tooltip:
The text of the tooltip is specified by the Hyperlink command's Hyperlink Description option.
Hyperlink Cursor
Open url
Opens the location specified by the URL.
If a location on the Internet, BricsCAD opens the page in the default Web browser.
If a file, BricsCAD opens the file in the associated application.
This option executes the URL command.
See URL command.
Copy Hyperlink
Copies the URL to the Clipboard; the URL can be pasted into the drawing or other documents with the Ctrl+V shortcut.
See PasteClip command.
Edit Hyperlink
Opens the Edit Hyperlink dialog box for editing the URL, description, and other parameters.
See Hyperlink command.
-Hyperlink - attaches hyperlinks through the command bar.
Hyperlink - attaches hyperlinks through a dialog box.
Settings - sets options for hyperlinks in the Files section of the Settings dialog box.
Browser and Url - open the default Web browser.
OnWeb - opens the Bricsys home page in your computer's default Web browser.
Mail - attaches the current drawing to a message in the default email client.
