Overkill
Deletes duplicate entities and overlapping lines, arcs or polylines and unifies partly overlapping or contiguous ones.
command bar:  overkill
: overkill
Select entities: (Compose a selection set, then press Enter.)
Entity properties to ignore
Selected properties are ignored when comparing duplicate or overlapping entities.
Comparison tolerance
Sets the tolerance for the comparison process. If set to 0 (zero), entities must match completely before being evaluated in the overkill process.
Options
If checked:
  • Maintain associative entities: associative entities are not processed.
  • Optimize segments within polylines: segments of selected polylines are evaluated individually, duplicate vertices and segments are removed. If lines or arcs duplicate a polyline segment, one of them is deleted, which might break a polyline, unless the Don't break polylines option is checked.
  • Ignore polyline segment widths: ignores the Width property of polyline segments.
  • Don't break polylines: polyline entities are kept intact.
  • Join collinear entities that partially overlap: partially overlapping entities are unified into a single entity.
  • Join collinear entities when aligned end to end: collinear lines and polylines having coinciding endpoints are unified into a single entity or segment.
-Overkill - deletes duplicate entities and overlapping lines, arcs or polylines and unifies partly overlapping or contiguous ones; prompts you in the command bar.
Break - erases a portion of an entity.
Erase - erases entities from the drawing.
Join - joins lines, LW polylines, 2D polylines, 3D polylines, circular arcs, elliptical arcs, splines and helixes at their common endpoints.
Oops - returns erased entities.
Purge - removes unused named entities from drawings, such as unused layers and linetypes.
Trim - removes portions of entities.
U - unerases erased entities.
Undo - unerases erased entities.
