Pro, Platinum
Pro, Platinum
Pro, Platinum
Revolves 2D closed entities to turn them into 3D solids.
command bar: revolve
alias: rev
menu bar: Model | 3D Solids | Revolve
toolbar: 3D Solids | ![]()
: revolve
Select entities: (Choose one or more closed 2D entities.)
Entities in set: 1
Select entities: (Choose more closed 2D entities, or press Enter to continue.)
Specify start point for axis of revolution or define axis by Object/Xaxis/Yaxis: (Enter an option.)
Specify angle of revolution <360>: (Enter the number of degrees, pick two points, or press Enter for the default.)
This command revolves only closed entities: circles, ellipses, closed polyline, closed splines, and regions.
The axis can be defined by two points; a line or a polyline segment; or the x or y axis.
The axis must be outside of the entity being revolved.
dmRevolve - creates 3D solids by revolution of closed 2D entities or regions about an axis.
Sweep - creates a 3D solid by sweeping a closed 2D entity along a path.
