Pro, Platinum
Pro, Platinum
Pro, Platinum
Extrudes 2D entities to 3D solids.
command bar: extrude
alias: ext
menu bar: Model | 3D Solids | Extrude
toolbar: 3d Solids | ![]()
: extrude
Select entities: (Choose one or more closed 2D entities.)
Entities in set: 1
Select entities: (Choose more entities, or press Enter to continue.)
Specify height of extrusion or Path: (Enter a number, pick two points to show the height, or type P.)
Specify angle of taper for extrusion <0>: (Enter a number, or pick two points to show the angle.)
Any closed 2D entity can be extruded, including regions.
The resulting entity is a 3D solid.
Grips Editing
Extrusion can be edited directly through grips:
Select the extruded solid. Notice that it has two grips.
Drag a grip to move the extrusion. (Both grips perform the same functions: move.)
dmExtrude - creates a 3D solids by extruding closed 2D entities or regions.
Sweep - creates a 3D solid by sweeping a closed 2D entity along a path.
