-Units
Sets units of linear and angular measurements in the command bar.
command bar:  -units
transparent:  '-units
alias:  -un
status bar:  x,y,z-coordinates
: -units
Unit mode (LUNITS):
1. Scientific    4.225E+01
2. Decimal       42.25
3. Engineering   3'-6.25"
4. Architectural 3'-6 1/4"
5. Fractional    42 1/4
Unit mode 1-5 <2>: (Enter a number.)
Number of decimal places for LUNITS 0-8 <4>:  (Enter a number.)
Angular unit mode (AUNITS):
1. Decimal degrees           90.0
2. Degrees/minutes/seconds   90d0'0
3. Grads                     100.00g
4. Radians                   1.57r
5. Surveyor's units          N 00d0'0"E
Angular unit mode 1-5 <1>:  (Enter a number.)
Number of decimal places for angular units 0-8 <0>:  (Enter a number.)
Angle 0 direction <0>:  (Enter an angle.)
Do you want angles measured clockwise? <N>:  (Type Y or N.)
Unit mode
Specifies the units of linear measurement.
Enter a number between 1 and 5 corresponding to the list:
  • 1 - Scientific, such as 4.225E+01
  • 2 - Decimal, such as 42.25
  • 3 - Engineering, such as 3'-6.25"
  • 4 - Architectural, such as 3'-6 1/4"
  • 5 - Fractional, such as 42 1/4
For metric units, choose 2 (decimal).
(LUNITS refers to the system variable that stores the type of linear units.)
Specifies the number of decimal places.
Enter a number between 0 and 8:
  • 0 - 0 decimal places, such as 0.
  • 1 - 1 decimal places, such as 0.0
  • 2 - 2 decimal places, such as 0.00
  • 3 - 3 decimal places, such as 0.000
  • 4 - 4 decimal places, such as 0.0000
  • 5 - 5 decimal places, such as 0.00000
  • 6 - 6 decimal places, such as 0.000000
  • 7 - 7 decimal places, such as 0.0000000
  • 8 - 8 decimal places, such as 0.00000000
This option affects the precision of fractions in architectural and fractional units:
  • 0 - 0 fractional precision, such as 1
  • 1 - 1/2
  • 2 - 1/4
  • 3 - 1/8
  • 4 - 1/16
  • 5 - 1/32
  • 6 - 1/64
  • 7 - 1/128
  • 8 - 1/256
Angular unit mode
Specifies the type of angular units.
Enter a number between 1 and 5:
  • 1 - Decimal degrees, such as 90.0
  • 2 - Degrees, minutes, and decimal seconds, such as 90d0'0
  • 3 - Grads, such as 100.00g
  • 4 - Radians, such as 1.57r
  • 5 - Surveyor's units, such as N 00d0'0"E
There are 400 grads in a circle.
There are 2*pi radians (approximately 6.282) in a circle.
The N and E in Surveyor's units refers to North and east.
(AUNITS refers to the system variable that stores the type of angular units.)
Enter a number between 0 and 8.
Angle 0 direction
Specifies the direction for 0 degrees.
Enter an angle, or pick two points in the drawing.
The default is the positive x axis.
You can also rotate the drawing through the Snap command's Rotate option.
Specifies the direction in which to measure angles:
  • Yes - measures angles clockwise.
  • No - measures angles counterclockwise (default).
Status Bar Menu
Right-click 72',42',0" (or other x,y,z coordinates) on the status bar for the shortcut menu:
Shortcut Menu
Scientific Linear Units
Chooses scientific as the working units.
Decimal Linear Units
Chooses decimal (metric) as the working units.
Engineering Linear Units
Chooses engineering as the working units.
Architectural Linear Units
Chooses architectural as the working units.
Fractional Linear Units
Chooses fractional as the working units.
Relative
Displays relative coordinates in the status bar.
Absolute
Displays absolute coordinates in the status bar.
Off
Displays coordinates only when points are picked.
Properties
Opens the Coordinates section of the Settings dialog box.
Coordinates
Specifies how coordinates are displayed in the status bar:
  • Update coordinates only when selecting points - equivalent to Off.
  • Coordinates always show pointer location - equivalent to Absolute.
  • Coordinates in polar form for point, distance and angle selection - equivalent to Relative.
Units - sets units through the Settings dialog box.
NewWiz - sets units and other parameters for new drawings.
New - starts new drawing in Imperial or metric units.
