New
Starts new drawings.
command bar:  new
shortcut:  Ctrl+N
menu bar:  File | New
: new
Choose a DWT template file or DWG drawing file, and then click Open.
When the StartUp system variable is turned on, this command displays the same dialog box as the NewWiz command
File name
Specifies the file name.
To open more than one file at a time, hold down the Ctrl key while selecting file names.
Chooses the type of drawing file:
  • DWT - specifies template files.
  • DWG - specifies drawing files.
Open as read-only
Toggles read-only status of drawings:
  • On - opens drawings read-only; they can be edited but not saved to the same file name.
  • Off - open drawings normally.
Use the SaveAs command to save by another name.
Template drawings are always opened as read-only.
Use Preview
Toggles previews of the drawing:
  • On - displays preview image in Preview area.
  • Off - does not display preview image.
Many template files are empty, and appear to not have a preview.
Open
Opens the file.
Procedures
To create a drawing using a default template drawing
To set the default template drawing
To create a drawing from scratch
To set the Plot style policy
To create a drawing using a template drawing
To create a drawing using the New command
To set the Template Path variable
To create a drawing using a wizard
Units - sets units through the Settings dialog box.
-Units - sets units through the command bar.
NewWiz - sets units and other parameters for new drawings.
QNew - opens new drawings.
