WorkSets
Creates and loads a set of drawing files. Allows to work with a named group of drawings.
command bar:  worksets
menu bar:  File | Working Sets...
: worksets
Select an option, then click the Next or Finish button.
NOTE
Since working sets are saved in the registry, they are defined differently in each user profile.
See the ProfileManager command to learn more about user profiles.
Opens all drawings that where open when the last BricsCAD session was closed.
Click the Finish button to confirm.
Opens an previously saved working set.
Select a named working set in the list, then press the Finish button.
Allows to:
  • Save the currently loaded drawings as a named working set.
  • Redefine (overwrite) an existing named working set.
  • Delete an existing named working set.
Do one of the following:
  • Click the Save button.
Type a name in the Workset Name field, then press the OK button.
Click the Finish button to conclude.
  • Select an existing named working set, then click the Save button.
    A Confirm Save dialog box displays.
    Click the Yes button to replace the selected set with the currently open drawings.
  • Select an existing named working set, then click the Delete button.
    A Confirm Delete dialog box displays.
    Click the Yes button to delete the selected set.
Open - opens drawing (DWG), template (DWT), and interchange (DXF) files.
